Looks like I need to replace the HDD in my FX503. Any advice re spec of HDD I should be looking for? Anyone replaced the HDD in the FX503 - what did you buy and any advice etc? I checked the spec section at VAIO-link but it didn't gvie any details except 20Gb (IDE) which isn't really very useful! I haven't got the handbook in front of me, but I assume the info at the same level as the website.
I suggest any of the IBM Travelstar series (which are Hitatchi now)
