I'd really appreciate some help with my laptop.
I had to replace my hard drive on my Sony Vaio (VPCEB4E4E), as it was faulty, but I didn't create backup/restore discs. Does anyone know if I can download the operating software with all necessary drivers etc.
I've tried the 'Assist' button and pressing F12 and F10 and F11 whilst restarting (not at the same time). I just get the same message 'No operating system found' so I guess I need an operating system 😕
This must be a common problem but I just can't seem to find an answer anywhere!
Heeeeeelllllllpppppp
Hi jayded1 and welcome.
As you have found out, the first thing you should do when buying a new Vaio is to make a set of Recovery Discs - you will have been reminded to do so when your Vaio was new.
Although you can download the Drivers for your model here: -
http://www.sony.co.uk/support/en/product/VPCEB4E4E/updates
you cannot download the Sony Windows 7 operating system or any other preinstalled programs and applications.
You can either buy a replacement set of Recovery Discs from Vaio Support (cost about £50) or you can buy a retail version of Windows and download the drivers from the above link.
If you choose to buy a retail version of Windows, you will lose all the preinstalled software. These will only be available with a replacement Recovery Disc set.
