Does anybody know how I can use the remote control to launch anything other than SonicStage when I press "MUSIC" on the remote control handset? I would rather it launches Apple's iTunes!
Thanks.
it is possible,please bar in mind i have a rz424 so things could differ but i doubt it, in your taskbar you should have a grey circle with a s inside double click on this icon. the vaio action setup window should open then click on S3 which is selected to sonic stage, this opens up the application select window from here select all files and browse to your i tunes folder and i think if u slect the exe file and follow the procedures this should work
Changing s-keys doesn't help
-remote seems to be tied to Sony Apps I'm afraid. I reckon I'm going to get one of those new Logitech keyboards with Bluetooth remote instead.
