can anyone tell me is it possible to unlock the region code and make the region infinitely selectable or region free on my pcg k115b
It is poss to unlock your drive to play all region discs but all the information is norm stored on your actual drive...almost like its own bios so you have to replace this.
You may find http://3dgamer.tripod.com/Regions.html helpful but as far as i know your nor allowed to do this and if you do it may valid the warenty.
If it doesnt help or sounds a bit in depth just search google
Again id find out if this is allowed though
take it easy
Just use a program like DVDRegionFree
