i am using FE 11S. i tried to burn a dvd by using Click to DVD program.
when i click on the Create DVD button , i am getting the following error message:
cannot detect the drive or the power is off. check that the drive is connected to the computer and turned on.
i dont know why this is coming. any suggestions
maheed
Hi maheed and welcome to Club Vaio.
Have you selected the correct DVD writer in File>>Settings>>General?
Perhaps you should try another DVD burning program - something like Nero.
Thanks,
i tried checking now and found that there is no drive found.
Any suggesions please
maheed
Maheed,
Have a look in Device Manager to see if your DVD/CD ROM drive is installed correctly. (Control Panel>>System>>Hardware>>Device Manager).
In Windows Explorer, does the drive letter (Usually F:\) appear?
Hi Blencogo,
Thanks for the information. i already did that and two days ago i upgraded the optical drive software from vaio-link site.
Last night i found that in the explorer it shows like DVD-RAM DRIVE(F:). I am thinking that it changed to take only dvd - disks.
i need to check it with a dvd - disk. until now i checked wih dvd + disks only.
If it works with dvd - disk how to get back my drive to work with both kinds of disks.
Any suggestions.
Thank you for your help.
maheed
