Helloooooo.... is very difficult to find the original case for the VP around the world...
What is the Ref. of the original soft case for the VP?? Anyone knows it!? or anyone knows an internet shop for buy it?!
Thank youuuuuuu byeee
JC
There used to be a slip-case on www.sonystyle.co.uk. You may wanna look around yourself.
Ebay is always a good option or if you feel like spening that lil'bit more you can always import by the link below:
Sony Style
Hope this helps!:smileygrin:
Thank you... but says...
"The product VGPAMC4 is currently unavailable"
i try to find it on ebay, but my experience in this shop is puajjjj!! **** ebay!! grrrrrrrr
Byeeee
majete
Hi, you can get the origional, leather slip case for your VP here for £14.99
http://www.unbeatable.co.uk/CatalogueItem_24412.html
Hope this helps
Regards
Hope this helps
Regards
and now... i can't see the image of the slip case... is the same as VGPACM4? What is the difference with VGPCKP1?hello.
the difference between vgp amc4 and vgp ckp1 is that the 1st one is the code of the product in america and the second one for europe or japan.
you can find a case here
http://www.microanvika.com/product.asp?TXT=INFO&PNO=SON19417
i got mine from there,its on the way for my home right now.
also its exteremely cheap comparing to other prices ive seen.
hope this one isnt out of stock too.
glad to help
Hey MadarbWot!! Thanks a lot !!
Is this the case?!
And Includes belt clip, belt loop, case strap and Pocket strap??
Is Doubtfully cheap!! uhmmmm...
JC
yes i know that its very cheap.ive bought mine from there and although i havent actually got it on my hands yet i can say that the whole procedire was very easy and i think personally quite trust-worthy.
dont know if the company is worth trusting all i know is that i had no prob with my case.
i recommend it.
ps.glad to help
