Hi there.
I instaled windows vista on my laptop,and now I can not run my recovery disc.To re install back to vindows xp. Any solutions,would be help.thanks
Please give us some help here.
What message do you get when you try to boot from the Recovery Disc?
What model do you have and have you read the Recovery Guide?
If you have not physically deleted your recovery partition you may be able to run the recovery without the recovery discs - from the hard drive. VConnect your Vaio to the mains adapter and press the power button. At the first Vaio Logo screen, press F10 contiuously and follow the on-screen instructions.
Hi.
Model is VGN-FE11H.I have remove recovery,but I got them on disc.I tryed your sugestion,but not working.Look like my DVD-RW can not play auto run. Every time I put on windows vista ask me to activate Windows,what I don't want.Any help welcome.Thanks
