I would like to know if there is someone having the vgn A317M recovery dvd...:smileyconfused:
I would like to get a copy.
Thanks:smileysad:
Seb: 5 now = 350 Euros!
You need to order it from www.vaio-link.com
i was wondering, izzit just vaio doing the recovery partition in the laptop itself or other brand also doing the same?... Btw.. unless you never own or buy any laptop/pc before, you should know that it should come with some system/drivers/recovery cds right?.. why formatted it unless you are sure you be able to install everything back?
Cause I copyed all datas in the partition (I got them) but i can't use them as they seems to be useable only via the recovery program.
There is a autorun program but it doesn't exe.:(
