Hey guys..
I need your help..i will reinstall win xp home and to do this i need a recovery dvd..but how can i make a recovery cd?pls help!
You need to use DVD-/+R depending on your drive, it will not work with RW.
In the start menu there's a program called VAIO Recovery DVD Creation (something like that, as mine has CDs I don't know the full name), start that and follow the instructions.
Shouldn't take you > 1hr.
