Do anyone of you have any idea how to fixed up the software? I had try to crate recovery disk but failed. I think due to windows problem. I use XP home service pack 2. I really sure that my windows got a problem because I cant even play colin mcray rally 04 with my vaio when I use window xp home When I format my pc and then install new xp pro SP2, then I can play that game. So, i really sure the problem is windows home. Really silly windows. So anyone of you have an idea to fix window XP home? Just to fixed it for create recovery disk. After I got that disk, then I of course will upgraded to window xp pro. Good bye to silly xp home.
Have you checked on Vaio-Link for a Vaio Recovery Utility update for your model?
