I have jusy fitted a Seagate 750g hard drive into my vaiao VGN NW20SF because the previous HD was corrupted, The recovery disc I created wont load because the new HD is to new and I need a newer version of windows 7. I have installed a newer version from a freinds copy with my windows 7 product key. If I now use my original recovery discs will it Re-install my Vaio Software or will it try to overwrite my newer version of windows 7?
