Where can I get a set of recovery discs for my vaio VGN-NR21J/S
Hi lsbarron
welcome to Club Vaio..
With most Vaio models you can create a set of recovery disc's by doing the following:
Click Start, All Programs, then Vaio Recovery Center..
Click Continue on the User Account Control window
Select Create Recovery Disc then press Start..
If you have removed you're Vaio's HDD recovery partition or replaced the HDD then you can purchase a set of recovery disc's by contacting Sony Vaio support either by clicking Support at the top of this page or use the following link:Vaio support
Once logged select Get In Touch
