Recently my pc has been behaving abnormally. I have tries to perform a system recovery with the product recovery cd-roms. I follow the instruction sas stated in the handbook but where the you are meant to enter S to start the system recovery the following message appears
CDR101: NOT RWEADY REDAING DRIVE E.
ABORT,RETRY,FAIL?
I can not seem to get by his and in all frankness i am stuck. :smileyblush:
Any ideas
It's sounds like your disks are either dirty or damaged. Clean the disks and try again.
If you can, see if the disks can be read in another computer. If they can then it could be that your drive is faulty.
If the disks prove to be damaged then you will have to phone Vaio-Link for a replacement set.
If this disc is scratched I would get hold of a skip doctor, apparently they can help you fix a CD. Not tried one yet, but if it fixes your RCD it's worth it's money.
