SZ1VP
Hi all.
Has anybody re-partitioned the HDD to provide three partitions?
I have made my recovery disks and created a floppy boot disk with MSDOS commands including FDISK and FORMAT.
I have not loaded any additional software or saved any personal data on the hard drive.
But....
Sony support won't tell me which DOS drivers I need for the DVD or where to get them.
If I keep the recovery partition but repartiton the rest of the HDD, can I reload the software from the F10 key on boot up?
SS:smileywink:
SS:smileywink:
Thanks for the reply.
So, I can't re-partition using XP itself (without shelling out for extra software).
If I use FDISK to re-partition the extended drive I'll loose everything?
Which DOS files I need on the floppy to access the DVD drive from bootup?
Thanks
SS:smileywink:
You could try partition magic, but many members said they couldn't use the HDDR as extra space due to the way the machine is set up. They had to do a full recovery.
If you go to bookdisks.com you'll find a Windows XP boot disk which allows you to access optical drives
Thanks for the info so far.
I don't want to purchase a third party program for just a single use.
Trying to get useful information out of Sony Support is like drawing blood out of a stone.
I'm thinking of removing all of the partitions except the recovery partition (although the laptop will boot from the DVD drive with the recovery disks in, it's just alot slower).
I may have to create a primary partition for XP.
There is a an Fdisk command 'MBR' which repairs the master boot record. Would this prevent, what you meant when you said I would "loose Everything"?
From what i've read, once XP is installed, I can partition the rest of the HDD using the disk management.
SS:smileywink:
No, if you do anything with the partitions you'll loose everything, no matter what.
MBR is if you get a virus in the MBR and need a fresh one
