Hello, i have model Vaio vgn-ar31s, and i have huge problem with my raid volume0, in last 4 days i recovered my system about 8 times... in my computer i can see message that, one of my raid volume fail, backup data imediatly! i had the same problem when i just bought this notebook, in garanty they helped me to fix that problem, with raid configuration, and it helped, but now if i do the same with that raid configuration, it helps just for 1 day, till i want to write something in my hard drive, my notebook stop respoding, and when i restart it, i got that message about my volume problem... Sony utilities cant find the problem it shows that everything is ok, i checked several time, just if i check with windows chkdsk when pass 52 % its stops respoding, and i have to swich off pc, i tryed all erase&wipe types, nothing hepls:(( garanty is 2 month over.. pls help me, what i have to do? buy new HDD? Sorry for my english im from Lithuania, live now in Germany.
Hi sabotaz,
welcome to Club VAIO..
Does installing the Intel SATA Driver 7.5.0.1017 driver update help.?
Use the following link to download the driver: Intel SATA Driver 7.5.0.1017
If not then I suggest you contact Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
