Anyone had this problem?
Turned on the RA104 to watch TV while doing a few bits and the tuner started tuning again! Not sure why this happened but it seems to be OK.
Right pain though, as I had to re-arrange the channels again. Gigapocket recordings still work thank goodness.
Strange
Well as this has had such a lack of replies and views I can tell you it's all OK now.
Thanks for the support guys, really.
Sorry Kee-Lo,
I tend to look at the message title and then the last post column and as your name was probably filling this column I guess I missed your post....:smileysad:
I've just sold my RA104 but I never experienced that particular problem during the 18 months that I had it.
Lots of others .... but not that particular one :smileybatting_eyelashes:
Kee-Lo, please... if all is ok what replies where you looking for?
"thank god all is ok again"
"phew, I'm really happy it is solved now"
"Yeah, sometimes they have a life of there own"
"Strange, maybe it was programmed in OPEN-R?"
If a problem is resolved and it only happened once, leave it as it is. If it should happen every time you reboot, that would be another story... If I should post every one-of we have (not only with Sony but also other brands) in the company I work for, I'd fill this forum unitill Sony gets a web storage problem....
But after some investigation most of the cases are actually realted to a pebkac.
No, just seeing if someone else had had the problem, wether it was a common thing to happen.
