Hello, I made a clean install of vista and now I want to setup instant mode but I could not find the program in vaio-support site. I am using FZ31Z and these are installed:
vaio update 3
appmon utility
setting utility series
sony video shared library
vaio bd menu data
vaio camera capture utility
vaio entertainment platform
vaio launcher
vaio original function setting
vaio power management
What else I need to install to run instant mode application (AV MODE) ???
Hi vbaykut.
the FN keys and AV keys are controlled by the Utilities packages, but unfortunately the utilities package for your model does not contain the utilities you require. ie AV Mode Launcher Utility, Sony Utilities DLL and Setting Utilities Series..
In the meantime if you want the AV mode then all I can suggest at the moment is to restore the original Sony OS and then uninstall anything what you don't want..
