Hello,
I can not run Bluespace NE application on my Vaio notbook. When I launch the application, nothing happens; there is no icon in Systray; no application in desktop. In the task manager I can see bluespace NE (memory usage:3.480k) and The blue light in the front of Vaio is on. I have installed several times this application without any success. Bluetooth is activated in wireless manager. I use wireless Lan without any problem. Everything in the notebook works fine, except bluespace, I have never used it, this is the first time I try to work with it. I want to communicate with others Bluetooth devices.
Here is my configuration
Vaio VGN-A117s ¿ 1GB Ram ¿ XP Pro Multi-language SP2
Bluespace version :
[InstallationInfo]
ProductName=BlueSpace NE
Version=3.4.00.13230
InstalledDate=9-24-2004 05:56:58
ProductGUID={3A62C3DB-2506-4FAE-A6DB-55D12A9BA370}
You're best using SP2's in-built bluetooth support.
Thanks, You are right. Bluetooth works fines with sp2 buit-in support.
Taysir
No problem.
