Hi. I have a Vaio VPCEB2M0E laptop. Pressing the WEB button for Quick Web Access launches the Splashtop Browser but it doesn't connect to my wifi network. I have tried to get it to connect by ticking 'Enable wifi' in the network connections dialogue box. It does a search for available connections but doesn't find any. I think it is an old version of Splashtop so it may just need upgrading. Can anyone help resolve this long-standing problem please/
Hi ridiroka,
Shot in the dark here but have you tried experimenting with different channel numbers on the router?
Also there is an update available on the support site (DVM Quick Web Access - 1.3.1.7). Maybe worth trying unless you are already running that version.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000227749_5305/VPCEB2M0E
Rich
Hi Ridiroka,
I'm pleased to hear that you have made progress.
I have searched, as I'm sure you have, with no luck in finding a more recent version. If you eventually find an updated version it will need to be installed via the Windows 7 OS.
Rich
