Bought a new VAIO laptop a couple of months ago.
Its got 128 meg and is a Mobile Intel(R) 915GM/GMS,910GML Express Chipset Family.
However I have had loaded pro evolution soccer on it and its great however I cant seem to get it running Call of Duty 2 or Imperial Glory that both use directx 9.0c.
I have loaded it ok but the applications wont run.
Do I take it directx 9.0c is not compatible with this graphics chip?
i have problems with the same chipset it should be fine for what i want to play but it wont work argggggggggg :smileygrin:
:smileygrin: :smileygrin: :smileygrin: :smileygrin: :smileygrin: :smileygrin: :smileygrin:
Try running a Direct X Diagnostics to see if it is DX causing the problem by Start > Run > dxdiag
Is it that they won't run or is it they're very slow and jerky etc.
According to Intel , Call of Duty 2 is not playable with the 915GM/GMS,910GML Express Chipset Family.
