Just after I've purchased my Vaio, I sudden clean all the junk-bundle pre-installed software out, and step 2, I've created the recovery set disk. Now the question is: do the recovey diskettes are really shareware free? Or since they are created from a restoring partition of hard disk, they still keep mantaining the originally installed software? If the second is the good one, I ask you all, if does exist a method to create a really purified recovery disk.
Thanks to everybody
purified recovey diskettes
Marco
Hi Marco,
Recovery Discs are copied from the Recovery Partition on your hard drive. You cannot change this partition and it will always recover the Vaio to factory settings - with ALL the original software.
If you want to back up your Programs/Settings/Data as they are now you have uninstalled the ones you don't want, you will need to make an Image of your C:\ Drive with something like
Acronis True Image 11
