I have a VGC_V3S and would like to know if I can attach a projector to view whats on the screen.
Thanks
you should be able to
According to the specs there are no video outputs so unfortunately you can't connect a projector.
You could get a USB TV card which has video outputs?
Right Click desktop and go to settings with the projector plug into the USB then click the screen 1 to assign to both the LCD and the projector. What projector do you have?
sorry i forgot to say if you bought a USB tv tuner or if it was usb
The projector I have is a Toshiba TDP-S9. It has a usb conection on the back, but says its for service only.
The I think the best thing to do is get a USB TV card
Ok, I will try the USB TV CARD.
Thanks for the help.
