Where is the program which tells you all the programs that were preinstalled on your vaio, and gives you the option to reinstall them.
Hi jackzelouf
Go to Start > All Programs > Vaio Recovery Tool and click on Vaio Recovery utility.
Once the Vaio Recovery utility has loaded, click the options button and select Recovery Specific Applications that were pre-installed, click OK, then Yes and Yes again.
