any ideas where i can find drivers for my camera with an xp version???????
You need to use your existing camera driver (VGP-VCC4) because the same driver is used for both XP and Vista. It will be on your original Recovery Discs or can be downloaded as part of the FE41S Original Drivers Package.
You will need the XP version of the Vaio Camera Utility to run the camera and this can be downloaded as part of the Original Drivers Package for the FE31Z which is the same as your FE41S except it was sold with XP.
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&m=2403
can i use this drivers for the same problem on my sony vaio vgn fe41zr ? my OS is windows xp pro
Yes it should work for your FE41ZR as well..
