Hello
I tried to install the latest VAIO Update on my VGN-FS415M anda after the donload from Vaio Link the instalation program stoped at the middle of the process.
I have been trying for some days now with no success.
Is there a solution?!
Also, with the Wireless Lan Starter I have problems. After the latest uptade i can´t make it work.
Help please.
Hi Jup,
Welcome to Club Vaio,
Go to C:\Update and open the SOAVUD-01451800-UN folder, then double click to run the file SOAVUD-01451800-UN.exe
This should re-install VAIO Update 3 on your vaio..
Did you run the wireless LAN starter twice, as per the installation instructions, the first time you ran the SOAOTH-00977103-UN should have removed the previous version and the second time yo run the SOAOTH-00977103-UN should install the new version..
Go to C:\Update and open the SOAOTH-00977103-UN folder, then double click to run the file SOAOTH-00977103-UN.exe
Click Next and wait while the wizard installs the new software
Click Finish when the installation is completed.
