Hi!
I installed the Hotkey utility, but they do not function. Original was on the VGN-A215M XP Home, replaced it with Professional.
Since then I cannot activate hotkeys.
Where the problem lies?
Thanks for your answer!!
Have you tried running the UTILS.EXE package from C:\UTILS to fix the problem? Also try VAIO-Link for Hotkey updates.
Thanks for your answer, but i forgot to install the SharedLibrary and Sonyutils.
mfg
