I need to connect my M1 VAIO to my PDA (IPAQ4770) and my smartphone (Sony P900). The conection softwares and cradles semm to be correctly installed, but connection is not possible. The Acctivesync is not able to connect.
USB ports seem to work correctly (printer & modem work perfectly).
Thank you for your kind help
Paolo
Italy
Hi
Have you checked that Norton isn't blocking it?
Seb
Because it comes pre-installed on all new VAIOs
Most people use the free days
