Hi to everybody.I bought a new Sony Vaio PCG-z1XSP that from the first day every 5 minutes freezes the cursor of the mouse for a while(usually 3\4 seconds) and sometimes if the cursor is on an icon it opens the program as if i doubleclick on it,but in reality i stay still...mah!I tried everything
1)no bluetooth activated
2)no wireless activated
3)configurations of the mouse set to very low sample rates for input and output
It is not a great problem but it seems as if the cpu elaborates something and then continues working without problems..
Anyone that could help me is a friend..
Thanx
Emanueol
You say that wireless is not activated, but is the card installed? This kind of problem is generally related to the Sony wireless card and the attendant software.
I can only suggest that you try VAIO link to check for any updates for your machine.
