Hi all..
I have the VGNS1XP, which only has VGA out..
I have just bought a Sony Bravia LCDTV, and it doesn't have a VGA input on it
I bought a cable off ebay which is a VGA - S-video lead.... I know its not ideal and won't give great quality, but it should at least work should it not?
I have booted the laptop up and the TV displays a black screen which flickers occasionally. I go to the desktop properties and try to attach the 2nd monitor, but that doesn't work..
can anyone help me? What am I doing wrong?
what will I need in the long run to be able to get HDTV from laptop to TV... will the docking station work?
many thanks
Phil
oops, would like to add that the TV has HDMI, component, S-Video, Scart and Composite inputs..
You may find something in the AVerKey range of products.
Yeah averkey is the lead i have,from maplin.
