After switching to Win 8, I keep receiving error message that I need to install mfc110u.dll. My VAIO model is Z series VPCZ227GG. Appreciate advice how to resolve this.
Hi nelsongjose,
Was this a clean install of Windows 8 or a migration?
Only a migration is supported for European models but as this is not a European model I am unsure whether it is fully support by Sony for upgrading to Win 8. You will need to check the support site in the region of purchase for any available Win 8 drivers and utilities as I suspect the missing dll may be connected with either Vaio Update or Vaio Care.
Rich
I've got the same problem with my Vaio S.
This was an upgrade from Win 7 Pro to Win 8 Pro.
VUDesktopToast.exe is missing mfc110u.dll
I found plenty of other instances of people with Vaios with the same problem when I googled it. One suggested resolution was to use this: http://www.dll-files.com/dllindex/dll-files.shtml?mfc110u
but I'm not sure this site is trustworthy...so was hoping there'd be an update available from Sony.
