My touch pad worked properly but suddenly stops to work. I check in Control Panel/Mouse and everything was ok. Strange is that when I select text for example scroll is working but if I want to scroll some site or other thing it doesn`t work. Also if the page is longer and right side bar appears to scroll when I select it scroll starts to work but if I want just to scroll without pushing it doesn`t.
Is there anyone with similar problem or with idea how to make it work properly ?
