I've got a big problem with my VAIO on Need for Speed Carbon. When i Start the game i think there's to much bass an because of that i do not get a clear sound. How can i solve this problem. In NFS there's no option to change sound options in a specific way...
thanks for regards
What happens if you lower the volume?
Don´t know what is your laptop, but i had a problem with crackling sounds on some games. It was solved by adding the games to the "Programs NOT affected" list, on the SonicStage Mastering Studio audio filter options!
Dunno if you even have that installed, but if you do, try it! 🙂
