The Problem is, I can't connect to my network, I've got the key and it doesn't work... but I can connect open networks.
I can't find the reason why I can use open networks but not my own.
:smileythinking: Can somebody please help me
Hi aalen and welcome to Club Vaio.
I'm afraid we will need more details - there are so many ways to connect wirelessly these days.
Are you using a Router - if so what make and model?
Have you run the setup program on the Router and set up a wireless network with a SIDD?
Have you run the wireless network wizard on your Vaio?
Can you connect using an network cable?
The Router is an D-Link
the network is set up porperly since i can connect to it with other pcs.
ssid is set, and i can connect with a network cable
Are you using the wireless utility? Because Windows' options are pretty difficult.
i have tried both using the windows settings (set all the stuff to the same setting as on a different pc that is able to connect to the wireless lan) and the intel wlan utility wich did not work either.
Can you connect to the router via ethernet?
I bought a new Router and now it works.
