Hi, I have heard that you can put lyrics on for each track you have on your pocket. I have found out how to do it but it does not appear on the vaio pocket.
I have put lyrics under the section called " lyrics " in sonicstage. but when i click lyrics on the player it searches for them , finds something but doesnt display it.....
Anyone had this same problem, if so have you resolved it ?
Greetings dmslider
if You load lyrics in SS but does lyrics not appears on the vaio pocket
make sure You have those settings:
I. OPTIONS -> TRANSFER
mark "Include additional information when transfering tracks to the memory stick or network walkman"
II. OPTIONS -> TRANSFER -> TRANSFER MODE
ATRAC AUDIO DEVICE -> SET TRANSFER MODE
mark "minimum bit rate transfer mode (atrac3 plus 48kbps)"
or just make sure You're transfering Atrac files because lyrics doesn't work with MP3
hi i need alot of help with this, how and where is the folder for lyrics, and if i have to crate it where, is this all through sonic stage?? please help,
david
