Hi ,
I have purchased Sony Vaio laptop(Laptop Model : VGN-FZ21E) in UK in the year 2007.
Problem Details:
Many application are not being supported by windows vista.Hence I want to
load the Laptop with Windows XP ,where all the applications are
supported.While I was trying to install the XP ,it allows until the
partition and after that it says check with the manufacturer and doesn't
allows me to progress further in installing .Could you please guide or help me to install the Windows XP software.
Thanks well in advance.
Thanks,Venkat
