Hello people !
I'm the proud owner of a new Sony Vaio VPCEB4Z1E.
The problem is that, when i'm trying to play FIFA 11 the button combination "
"DOWN"+"LEFT"+"S"
or
"DOWN"+"LEFT"+"A"
or
the same with "RIGHT"
is NOT WORKING.
Is this an hardware problem WHICH can be solved or i have to live with this???
i'm thinking of going back to the shop and tell them to replace it with a new one but if this is a common problem i won't go ?
Please answer as soon as possible - Thanks
Hi.
This is hardware problem. There is no solution.
Some keyboards aren't designed to have more than 2 regular keys held at the same time. If the game supports it you would be better off using a gamepad/joystick.
