My PC is a sony all in one and the model no on the back states it is a PCG-2A1M.
I am looking for the video card so I can install the driver for it as I have recently updated to windows 7. I have visited the support site but it is saying the model no is not recognised?? HELP.......
Hi shathomp6,
The MultiMedia controller will be the AverMedia Hybrid TV Tuner Card M115S. Sony has not released Windows 7 drivers for this but the original Vista driver may work.
http://www.sony.co.uk/support/en/content/cnt-dwnl/VGC-LT2SR/list
The same applies to the camera driver – try the original Vista driver.
Rich
I think you are quoting an invalid Vaio model. It looks like you are quoting the chassis type which can be shared by several Vaio models.
Have a look on the screen surround, or look in Control Panel -> Vaio Control Center for the correct model.
I guess it will be something like VGC-LTxxx.
You are right I have managed to find the correct model no and it is a VGC-LT2S
You have the NVIDIA® GeForce® 8400M GT GPU.
Unfortunately, Sony do not appear to support Windows 7 on your model. You can find the Vista drivers here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGC-LT2S
Most of these will work with Windows 7 but the Graphics Driver may not work.
If you cannot find a driver, you may have to try a Windows 7 nVidia driver from another Vaio model.
You can try the nVidia driver Ver 8.15.11.8640_0910130 released for Windows 7 for the Vaio 9600M GT in the AW21S. I have not tried it, so it is at your own risk. You can download both 32-bit and 64-bit versions from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW21S_B&os=10
Apologies for the late reply as I have been rather ill and only just now back on my feet.
Many many thanks for the time you took to reply to my problem. I hit very lucky and a friend managed to sort it remotely using Team Viewer6.
I believe your reply helped him a lot and I'm pleased to say my pc is back up and running again.
You're doing a great job - please keep up the good work (helping pc numpties like me).
Hi
I too own the same PC...VGC-LT2S...I too installed Windows 7...I too have a problem...
I now need Sony Vaio driver/s for Multimedia controller, or anything that would do the same job please.
The built-in webcam is dormant amongst other media headaches...
TIA
Hi shathomp6,
Rich
Big THANKS Rich
Most of the Vista drivers are looking good...
