Hi, i have a Vaio VGN-N21M. My disk space is 1000 Gb.
In Disk Management a see 2 partition, classic C (83 gb) and a partition with non letter, called Integred - EISA Configuration (9 gb??).
What is this partition?
What is used for?
Can I delete it and create a new usable partition??
thx!
Hi lucas_06,
Welcome to Club Vaio,
The eisa partition is a hidden Recovery partition..
This allows you to recover your Vaio back to the original factory set pre-insatlled operating setting and applications, also you can create a set of recovery disc's by running the Vaio recovery utiltity..
You can if you wish delete the recovery partition , but, if the recovery disc's that you created fail to work, or the CD/dvd drive fails you will be unable to restore your Vaio..
thanx for your fast aswer...
I have another little problem...my notebook is new...i buy it yesterday...
Now i have only 53Gb of free disk space, very strange...i have 6gb of multimedia file, so windows vista + standard sony software, microsoft office 2003...ok..this take 30gb of disk space!!...Very strange??...What can I do?? I make a disk scan, a defrag, a scan for file more then 50mb..but nothing strange...do i format?
Hi lucas_06,
You should also have a D drive..?
I have a feeling Sony have dispensed with the 😧 Drive on the new models?
I think they come with just C: and the Recovery Partition.
I have only C
