Hi
Just got my sz2xp and its amazing, but bit stuck on the wireless side. Could anyone tell me if the sz2xp has the capability to connect to a pre-n router or will i need to buy an adapter?
Hi adam723,
Welcome to Club Vaio,
The wireless LAN on the SZ2XP only supports 802.11 B ang G, this does not mean that you can not use your pre-n router as it is probably backward compatible, check the settings of your router to ensure that is is not set to Pre-N only.
If you wish to use Pre-N only then you will have to buy either a pre-N PCMCIA card or a USB adapter...:smileywink:
