I just moved my documents from the old desktop on the new vaio notebook, and I had a little surprise: I can't find any pre-installed application able to open a .ppt document. Doesn't really Microsoft Works 7.0 (French version) have this feature?
And one more question: is there a way that I could get an installation DVD in the English version? French is not very suitable for Windows...
Thanks,
Cris
You need Microsoft Powerpoint to open a ppt document. If all you want to do is view the file then you could try Powerpoint viewer from http://www.microsoft.com/downloads/details.aspx?FamilyId=D1649C22-B51F-4910-93FC-4CF2832D3342&displa...
Thanks for your quick answer. I wanted to make sure that Works 7.0 doesn't have this - I'm not used to it yet, and I saw it can manage word, excel and access applications (so why not powerpoint?)
About my second question, I just saw the problem was already raised on the forum and there is no solution for it: Sony doesn't provide its customers with a recovery CD in the native language of Windows. Now that's a bit strange...
Works will open .xls (Excel) files but you will not have the same functionality as with Excel.
Interestingly, Excel will not open Works files
I'd go with Kee-Lo on this - if you are going to be using Excel, Powerpoint etc I'd definitely recommend getting MS Office, if you haven't already. BTW Office XP is significantly better than 2000 :smileygrin:
