I would like to change the power supply fan, on pc PCV-RX 402 .(IS Noisy) which is-SUPERRED DC 12V 0.47A CHB 12012DS-A CHENG HOME ELECTRONIC CO.LTD-that I cannot find it any where.Is another one different make to replace it? please help me.. thank you
do you know the details of the power supply?
i have one here that may be what you need
Hi sorry I didn't answer to you cos I was very ill. So you have one psu DS 12V 0.47A CHB12012DS-A? How can I buy it? please let me know.thank you
Hi sapounadas
welcome to Questions & Answers..
It maybe worth contacting one of Sony's authorised repairers to see if they could supply with the part.To find contact details..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
If you're unable to source the part from one of the authorised repairers then you could try contacting vaio support, contact details can be found as above..
