I am the proud owner of a Sony Vaio PCG-GRT816S(GB) (PCG-8N2M) . This is fitted with a DVD-RW (Pioneer DVR-K12D)
My desktop computer is fitted with a Pioneer DVR-A03 DVD-RW and when I began to use the latest DVD-R 4x media in it, chaos ensued. This was eventually cured by updating the driver,
Am I going to have the same problem with my Vaio and if so, what do I do about it please?
RonWalker, i am afraid i cant help you with your question, but it might be a good idea if you took your serial no. off the forum, as someone else could register as you and get free downloads, and possibly access private info.
Very good point Harry
Please remove asap.
I have no idea if you'll have the same problems Ron, you'll have to test.
If you do have problems come back.
Thank you. I take your point and will remove it when I can find out how!
Yours aye, Ron.
Thanks Ron.
