i have bought the vp today, have charged itfor a few hours before switching the thing on then after 20 seconds it comes up with a list of languages, i select english, but it keeps on scrolling through the dont touch, do touch then back to the language screen again, is this normal or will i have to take it back to the shop for a replacement, thanx....:smileycry:
I has the same problem when I first turned mine on as well. You need to press the reset button on the bottom of the unit, and then try again ensuring that you do not touch the G-Sense pad until after it self configures. Good luck
have reset it a few times now but it wont config itself
Take it back and change it
i have bought the vp today, have charged itfor a few hours before switching the thing on then after 20 seconds it comes up with a list of languages, i select english, but it keeps on scrolling through the dont touch, do touch then back to the language screen again, is this normal or will i have to take it back to the shop for a replacement, thanx....:smileycry:![]()
make sure you are pushing the buttons hard enough. remember they push in, I forgot that, and sent it back. WOW, that means I've had 3 VP's:smileygrin: :smileygrin: :smileygrin:
have took it back and got it changed, its now charging and it wont be switched on til its fully charged:smileyhappy:
but thanks for the tips guys, i was gonna get an i-pod photo but there too common now
glad you did'nt follow the crowd and get an i pod, the vp is far classier.:smileygrin:
just to update on things, i now have a working mp3 player
i am sooo glad i didnt go for the i-poo, whoops pod.
and in the emortal words from macdonalds "i'm loving it"
cheerz for all the help guyz
Yey !!! Well done...
I'm sure you'll be pleased with it.
Everyone who sees my VP is impressed with it's looks and sound
I showed my VP to my best mate today and he immediately drove into town and bought one.
Still on sale for a bargain £199 from Dixons
Don't forget to do the upgades to Sonic Stage and Firmware.
http://www.vaio-link.com/vaiopocket/firmware/firmware.asp?l=en
You will then have gapless payback , native MP3 support and loads of other features.
Do thing in sequence and above all READ the instruction and follow them pecisely.
The headphones that come with it are a OK - just , so you may consider upgarding to something like SONY MDR-EX71SL
http://www.sony.co.uk/view/ShowProduct.action?product=MDR-EX71SL&site=odw_en_GB&category=HEA+Walkman
They are about 30 quid from Argos. They take a bit of getting used to, but they are very good if you stick with the rather strange "blocked ears" effect they have on you !!!
]Have Fun:smileyhappy:
