I have a Vaio (pcg-fr395ep) and there is something wrong with it.
when I connect an external mouse to it, everything is ok but suddenly the pointer drops, or open the right-click list without I push any button.
plz help me what should I do?
thx
You can try the following:
click "START"
select "Run"
type "msconfig -6"
click "OK"
deaktivate the check-box in fromt of "APoint.exe", click "OK" and restart your machine as asked.
See if the problem is solved.
Good luck
