I would be really grateful for someone's help.
I have a Sony Vaio Media Center PC (XL301) and it came installed with Vista as the operating system. I am unable to play anything from sites that require the most up todate flash player; i.e. bbc iplayer, youtube etc
I have googled the probelm and a common solution seemed to be http://www.eggheadcafe.com/tutorials/aspnet/2a257c6e-700c-4c95-94a8-3712c676eb02/flash-fix-for-windo.... I attempted to follow this but it appeared that the two flies were flash9f.ocx and flashutil9f.exe. However I changed the properties as advised and ran the exe but this still hasnt helped.
Can somebody please help
Thanks
Sharon
Try downloading the newest version - here
After doing so restart the machine and try again.
I had this problem for a while and this seemed to fix it.
Thanks Matt, thats the link that I tried originally but just doesnt work and the page has the message 'Erroe on Page' in the bottom left hand corner.
I presume that you are using Internet Explorer?
Do you download the installer or does it do it with the browser window open if it does anything at all that is?
Hi matt
I basically click on the download button and after a few minutes the page reloads with the 'Error on Page' message in the bottom left hand corner and no flash movie appearing
is there another method of installing??
Thanks
S
Try this link which will download the installer. Close all browser windows and then execute the file - restart and hopefully it'll work.
Thanks Matt, appreciate you helping me with this. I clicked on the link, closed all applications/windows and then ran the link. I then restarted the machine. Once restarted I went to youtube abd am still getting the same message
