just bought a new laptop NS20E. Installed windows live messenger, but when I try to send my
webcam it doesn't allow me to.
any suggestion?
This can be caused by McAfee antivirus. The BrowserAssistant keeps monitoring the camera so you get a message that it is already being used.
All you need to do is update the main software from McAFee and the camera should be found automatically by Windows Live Messenger.
http://service.mcafee.com/faqdocument.aspx?id=TS100463
