I DON'T HAVE SOUND WHEN I MAKE A VIDEO CALL ON windows live messenger..
anybody knows how to fix this???
PLEASE IF YOU FIND THE SOLUTION IN GREEK IT'S BETTER FOR ME.
THANX!!!
Hi there
Have you set the correct devices in tools - audio and vidio setup?
yes maybe i need the right drivers
because the volume bar appears but i can't move the bar up or down to high o low the volume.the bar is always down.
