I've noticed this is a common fault but i cant seem to fix it using anything i have found online and in forums.
I have a VGN-AR61M Laptop that i installed windows 7 on. My webcam now isn't working.
Whenever i try and use it in MSN it says it is in use with another program. When nothing infact is using it
Vaio Camera Capture utility doesn't work at all or give an error message.
I come from an IT support background but this has got me stumped.
I hope you can help
Regards
