I wanted to restore my first hard drive but it doesn't work
I've restore the second part with the system of gestion.
But now after back up all my files on my new (second hard drive) I want to restore the first in NTFS for all part. I put the CD restore and I restarted the computer . The problem is that the CD rom is not reconized
and I can't do anything
I have an other solution but it's risky
Format the hard drive in the post of work
I don't want a solution like that because I have no back up to make it good.
If you have a solution please help me :smileyrolling_eyes:
Thank you for reply
Go into safe mode, and uninstall the CD-ROM, restart the PC and see if you can see it again.
How can I do to go into the safe mode ?
After you see SONY on the screen, press F8
Thank you Kee-Lo :smileygrin: I'll try this
And I will be back to inform you
I've just restore in a lower date .
Now I will try if I can to make the first part in NTFS with the CD rom of restoration.
Good news
I'm still in FAT 32
for the OS part .
I changed the size of the partition but it doesn't change the format
No it doesn't
Isn't there an NTFS converter?
(Make sure you backup first)
How can I do back up ?
Witch files I save?
