I have just bought this notebook VGN-FS515H vaio. The problem is , is that when i ordered it , it was a centrino m processor and yesterday when i recieved it it is a pentium m processor, (totally confused), is this right??? also i don't know how to look for the Gb's on this notebook, i should have 80Gb Please Help i'm really puzzled. thanks
Hi scouser06 and welcome to the forum.
The Sony specifications for your model list a Intel Pentium M Processor 740, not a Centrino. Who stated that it was a Centrino processor?
To check the hard disk size right click each drive (C and D) in turn in My Computer and select properties – this will display the capacity of each drive. Bear in mind that the total capacity of 80 Gig will only appear as 74 Gig due to the difference in the way the manufactures of hard drives calculate size as apposed to the way windows reports it. Long story but I will provide further details if you are interested.
Also you will have a hidden recovery partition that will occupy approx. 7.5 Gig so expect to see a total of approx. 66 GIG of storage capacity.
thank You For All You Help, A mail order company said it was a centino m processor, is pentium m better then centino m?
Sorry I may have confused you slightly with my reply.
‘Centrino’ is not the chip itself but a combination of things. ''Centrino’ mobile technology consists of three parts which must be present for a laptop to be Centrino certified.
The first is the use of Intel Pentium M processor (which you have), the second is the use of Intel's 855 chipset and the third is the use of Intel PRO/Wireless Network.
In short if all three are present in your model then it meets the Centrino certification.
Thank You ever So Much For Your help, My Laptop has All Three So It Is Centrino certified. It Make So Much Sence Now thank You!!:smileywink:
